engravers???
bert.
australia
what are you guys using to engrave your names into your tools? i'm looking for a good one to leave in my box at work so i can do my tools
also where abouts are you guys putting your initals on your tools?
would the dremel be a good choice as it has other uses? or a stand alone engraver?
rlitman
Long Island
A popular method around here is the one with a spring loaded carbon rod that you connect to a car battery. It kind of burns its way through the chrome. I'll see if I can take a picture of mine when I have a chance.
rusty65
Pekin,IL
I just use a old plug in engraver and i have yet to have a problem engraving my craftsman sockets.
MrKriez
I was just thinking about posting this thread. I am curious as well as to what everyone uses to label their tools.
bert.
australia
we dont have hf in australia i'm not sure weather thats a good or bad thing
bert.
australia
i'm keen to learn a bit more about this one
volvo92906
Northwest Ohio
I have the same kind as what HF sells, except I got mine at Lowes. It works well and is a normal AC wall plug. Never had a problem engraving anything.
OccupantRJ
Eastern North Carolina
I have used one that was nothing but an electrical transformer with a 120 volt line cord on the primary input, with an alligator clip and a copper rod attached to the secondary side, which is low voltage. The alligator clip lead was attached to the part to be engraved, then the copper rod attached to the other lead was used to spark write with. Output voltage was 6 volts.
YOJIMI
I've got one of the Army-surplus ,transformer models , uses a copper coated carbon rod , and gets hot enough when you crank it up , you can solder with it
JIMI:shocking:
Givl Reggin
Hawaii, USA
Hand engraving? What is this the stone age?
You can now get 60-watt Laser engravers for under $1500 bucks that will give a professional look like nothing else.
helterskelter
