engravers!
wrenched87
Waterford MI
What's the best engraver out? Are they all the same? Got a matco one and its china trash. It does the job but looks and feels cheap. Do they all rate at the same specs? This ones 7200 spm with a 30 min duty cycle.
OccupantRJ
Eastern North Carolina
A rotary engraver works better than an impact type to me, as they write like a pen. I also have a homebrew electrical arc engraver for hardened steel use. It's simply a heavy duty 120 to 6 volt step down transformer.
OccupantRJ
A dremel with a carbide burr works well, just a little bulkier to hold. harbor freight has a cheap set of diamond burrs that work pretty well for a lot of things.
Alan Douglas
Cape Cod, Mass.
I have two pantograph engravers, a Green and a New Hermes, but a Matco seems to be a hand-held model. The pantographs are best suited for flat panels.
Haveblue
kansas
"A dremel with a carbide burr works well" Thats what I like to use. Once you get a feel for the right speed, and pressure, you can engrave just about any material with good results.
cinco
Northern CO
Years ago my father picked up a used GraverMeister and produced some spiffy results. I played with it enough to get a feel but that's the only machine I have any experience with so I can't compare quality.
Freehand rotary tools are the engraving equivalent to peeing your name in the snow - they'll do the job, but do you really want anyone to see the result?
