Enlarging Chimney Opening for Water Heater
avc8130
Installing a new water heater. Upgrading from a 30 gallon to 50 gallon. Town inspector says greater than 35,000 BTUs requires 4" flue. I currently have a 3" and the new WH is 40,000 BTU.
What is the easiest way to open up the chimney hole to allow a 4"?
Air chisel?
ac
Hlidskjalf
Toronto
Well how long is the chimney? I have no idea how you're gonna ream out an entire length of the chimney. You need to fit 4" b-vent, correct?
I don't know about your local codes, but b-vent is mandatory here.
Might still be cheaper to get a power vented water heater, they're pretty inexpensive.
A
avc8130
The inspector said the 3" galvanized flue going through the cinder block with terracotta liner needed to be 4" galvanized.
ac
