If you use a 24 or 28 inch door because you have to that is one thing.
But if you can go 32 inches wide do so.
Every time you try to move something in through your entry door you will be sorry with a 24 or even 28 inch door. On a 24 inch door, you opening will only be about 22 inches or less, unless you remove the door or you can open it flat against the inside wall.
