....My point is for the same money you can buy a saw that is way better made
As for shortcomings OK
1 Engine cover one lever holds it on over time, not long really the tension gets sloppy if you don't notice the lever is down when you go to start the saw the cover flies off.
2 carburetor linkage, the linkage has a pinch connection had it pop out on regular use on two of the saws.
on a Stihl? have not seen that one yet unless it's on a top handle which is not a home saw. See it all the time on Husky family saws of all levels tho.
3 Air cleaner works about as good as a diaper.
That would be quite possibly user error either in maintenance of the filter (high pressure air to clean it) or installation either of could be the same on any brand saw. As a tech they all teach you to inspect the filter and inside the filter looking for debris that has somehow bypassed the filers then investigate the source. Stihl teaches it as part of the routine "engine check" process a tech is supposed to follow on every piece of equipment serviced for any reason. I will say I do like Husky's 1/4 turn filter style, tho almost everything out there in the past 20 years is light years ahead of what we all used to have. Remember the felted flat square with a rubber edge that was supposed to be pressed in place by the cover and never sealed right. I'm thinking specifically of Macs.
Overall fit and finish is cheap the picco chain does cut nice I will give it that.
I am using echo saws that cost the same for 5 times the amount of hours and counting so yes I am calling them junk.
Most home saws will never see 200 hours but stihl took a lot of shortcuts and they should be better than that.
I don't have brand loyalty I use what works.
So I only had time to open and test out the blower. Started in two pulls out of the box. Dried my car in less than 3 minutes. Haven't done any yard work yet but totally worth it already!
Bought the Echo for $130 after coupon and all so totally worth it. Still trying to decide if I should get the pro grade hedge trimmer, HS 46.
Keeping the saw for sure though.
The homeowners stuff is more the name than the quality
Just a quick bump to my thread.
So to add to my Echo chainsaw, hedge trimmer, and blower. I purchased an Echo SRM-225. Again, after a long research on Stihl and Echo, I ended up with another Echo.
Not sure how exactly it works for 3 on one receipt - maybe your guy can sell one 6 pack and register all equipment with it. I know the unit and oil need to be on the same receipt to qualify.
OP, there are lots of stories about newer Echos having repair issues, as mentioned above.
From my own experience, this is most likely due to the EPA-mandated non-adjustable carburetors combined with alcohol in the gas (which attracts moisture which then corrodes the aluminum inside the carburetor, blocking the fuel passages). And this is not just an Echo problem.
