That minagerie gentlemen in the hf (yes i know i couldn't get a better one on short notice thanks for being out of stock autozone) breaking off inside the damned fuel line which inturn locked the barbs around the fuel line (disconect kit my ***)
was that the metal buurerfly type of disconnect?.....if so, pure garbage, get the plastic ones by lisle............and next time jersey, call on us for sdvice no matter how trivial it seems , coulda saved ya trouble as there are threads on here about those types of disconnects.............
I bought the metal disconnect the first time thinking "metal is better than plastic". 2 hours later I was back at Autozone to buy the plastic on and had the line off in minutes.
I have never used the plastic one but I hear they work great. I have a full set that are made of aluminum and they have always worked great. Don't know where I got them or who makes them, so not much help I guess.
HF have several different set of tap and die. Avoid the really cheap ones. They are pretty crappy and useless. If you do get the HF, get the much higher quality ti-nitrate coated version. They are only for medium duty. If you plan plan to work with high strength steel, you should go with a professional brand.
