Well, I tool the plunge.
I had a full kit of grey, Company would not exchange for Bright Red, so I bought another kit.
GARAGE IS 440 SQUARE FEET
TEMP 50
New slab, (older than 90 days). degreased and scrubbed with simple green. Scraped floor with razor blade, washed again. Let dry for a day. swept, shop vacuumed several times and blew it with leaf blower several times. Prepared the etch solution.
In the end all was satisfactory.
Issues:
* Etch solution wasnt enough.
* Activator had trash in it. black bits of who knows what.
* Squeegee was a joke
* Cut in brush was broken
* Coverage was thin.
As it was the decreased temp. gave me additional working time. I hadnt inteneded on using the flakes, but because the coverage was insufficient it left me no choice. The flakes really do hide alot of imperfections.
I had to scrammble to try and get some type of coverage on entire garage. I didnt even cover the apron or an area of 10 sgare feet where the steps were. I had to make it very thin to get full coverage. So, thin that it was transparent in spots. The only saving grace was that I had time to work it back and forth to try and even it out. If it had been a little warmer and set up time a bit faster it would have been a disaster.
Floor endded up looking great! I had a few small spots where it wouldnt adhere. Dont know why, I am a nut for proper prep. Total time for Prep was in eccess of 10 hours. I am sure that it is something with the concrete and not the Epoxy. I made my own epoxy shoes and they worked great!
Suggestions to DIYers;
* Buy a real 18" squeegee that you can screw in an extension handle.
* Buy 2 rollers made for Epoxy.
* Plan on spending more than the prescribed 3 hours.
* Make sure to scrape floor with good putty knife or razor blade. I did both and found that the razor was quick and more effective.
Suggestions for EPOXY-COAT:
* Dont waste money on the squeegee
* Dont waste money on the cheapest brushes ever made.
* provide a bit more acid crystals to make 6 quarts of solution, not 5.
*** ADD MORE PRODUCT, OR ADVERTISE COVERAGE CORRECTLY!!
All in all, I am please with results.
But, it does get old when suppliers overstate their product specifications or add useless FREEBIES.
This is a considerable cost to anyone to cover a floor. The only things that save me was;
* That I expected the squeegee to be inadequate and bought 2 others. One of wich was notched. However because of coverage it was useless.
* It was cold enough that I had time to spead it out to cover.
* Flakes hide a multitude of flaws.
Hope this helps.
TEMP 50
Issues:
Hope this helps.
