Epoxy anti-slip/silica question
grawil
I'm doing a small residential basement floor that is intended to be a combination utility/laundry area. I am wondering if I should apply the anti-slip colloidal silica uniformly over the floor or if I should apply it heavier on a path leading from the door to the laundry machines?
Thanks
G
grawil
That's what I get for posting after a beer. Try to sound smart, end up sounding stupid. :willy_nil
It's grit. Sold to me by the manufacturer. The question is whether I should apply it uniformly or heavier on the expected traffic route?
tncatadjuster
Memphis, TN
It's grit. Sold to be by the manufacturer. The question is whether I should apply it uniformly or heavier on the expected traffic route?
Hey we were just having fun.:evil:
Uniformly produces the best aesthetic results, if you don't care what it looks like, then put it where you need it.
I always try for an even look.:beer:
G
grawil
Thanks guys. You recommend broadcasting as opposed to rolling it in from a tray?
LegacyIndustrial
deerfield, IL
Depends what you are using. Heavier media like aluminum oxide or fine sand will sink like a rock, better for broadcasting. Tabular alumina can be mixed in and worked from a tray.
deosola
So Cal
Tabular alumina
How "soft" is tabular alumina compared against aluminum oxide or the engineered polymer that Alpha Garage sells?
I would like to use something that won't make it hard to clean. From what I read, aluminium oxide does make it hard to clean (and my experience confirms that).
