dcs Inc
Elite Crete of Indiana will again be holding a Training and Certification on May 17 & 18. Due to the popularity of these certification courses, attendance will be limited and therefore sign up sooner than later to obtain your space.
The following products/systems will be discussed, applied and taught:
- Basic and advanced surface preparation for polymer modified, cementitious overlayments AND resinous flooring such as REFLECTOR™
Enhancer Flooring Systems and industrial floor coatings such as; neat finish and flake broadcast.
- Repair and decorative polymer modified, cementitious overlayments ranging from:
- Skim coats, surface repair coats and broom finish resurfacing.
- Splatter textures and knockdown decorative/non-slip finishes.
- Slate trowel down finishes.
- Thin stamped overlays replicating that of full depth stamped concrete and conventional stone and brick patterns.
- MICRO-FINISH™ toppings for creating cementitious ultra-smooth floors.
- Staining and coloring technique and products for polymer modified, cementitious overlayments:
- Using PORTION CONTROL COLORANT™ as an integral coloring system.
- Using PORTION CONTROL COLORANT™ with ULTRA-STONE™ Antiquing Stain for easy and natural looking coloring.
- Using CHEM-STONE™ Reactive Stain.
- Using HYDRA-STONE™ Dye Stain.
- Proper sealer uses and applications:
- The benefits of a reducable CSS EMULSION™ for a multitude of sealer uses.
- What makes CSS EMULSION™ the perfect outdoor sealer.
- Combining WCS EMULSION™ and CSS EMULSION™ on projects.
- Using E100-PT3™ as a CSS EMULSION™ replacement for interior applications over polymer modified, cementitious overlayments to obtaint he same look and feel safely.
- The ever popular REFLECTOR™ Enhancer Flooring System:
- Why it is the perfect commercial floor with industrial flooring strength and durability.
- How to easily obtain depth, colors and patterns to match specifiers needs.
- The truth about the differences in typical mica/metallic powders and REFLECTOR™ Enhancer.
- Popular industrial floor coatings:
- Flake broadcast - The perfect garage floor.
- Neat opaque epoxy finish - Perfect for industrial and manufacturing settings.
- Why 100 Series™ epoxies out shine (no pun intended) other similar products in terms of performance, use and durability.
- The differences between E100-PT1™, E100-PT4™, E100-UV1™, E100-UL7™ and SPARTIC-ALL™ RM.
- Other industrial flooring needs:
- What to look out for and plan for.
- Be mindful of moisture vapor and rising damp.
- When to use a primer vapor barrier such as E100-VB5™.
- When to consider slip resistance and what are your choices.
- Marketing your company and services:
- Think big, act big, perform big.
- Specifications are the key to your success.
- Typical contractor faults and successes.
- Other:
- Jobsite planning.
- Be mindful of profit centers and profit losses. This can make or break you.
Of course this is simply a quick breakdown of what we share in Elite Crete Systems Training and Certification Classes. However, come prepared to join in and participate. Be serious about this business as we will be serious about educating and teaching with the end goal being your profitability and success in this industry.
Breakfast, lunch and refreshments will be available both days. We look forward to another successful Training and Certification and your full involvement.
Contact us today to register:
Tel: (317) 888-4440
Email: [email protected]
- Other:
- Jobsite planning.
Tel: (317) 888-4440
