diamond grind, sweep, vacuum, acid wash stubborn areas, wet mop 4x, vacuum...Let dry for 3x the recommended time. Applied primer and allowed to dry 3x recommended time. Applied epoxy on a day where conditions were favorable (humidity/temp). Let dry 3x recommended times before driving on it....still had poor results.
Thoma, I feel badly that your concrete failed. I can't help noticing that you acknowledge your concrete was weak and failed but continue to feel bitter about the vendor .
They didn't pour the floor and they didn't perform the prep. You even mentioned that the customer service was satisfactory. Why are you sore with them?
