epoxy coat clear & spike shoes
jeff68bird
just got done color coat and flakes. waiting now the 18 hrs to able the clear.i will post pictures and write up on the other tread i started tommorow.this may be a dumb question but can you use the spike shoes to but down the clear or will it make marks and cuts in the fresh epoxy. i found myself walking in the wet epoxy a lot while appling the color. if i cant use the shoes any tips and putting down the clear??
LegacyIndustrial
deerfield, IL
Jeff: The spikes are for walking in wet high-build epoxy only.
If you walk on your new floor to apply the clear you will mess it up.
You shouldn't go on it until you can walk without getting stuck in normal shoes.
