Epoxy-coat finished finally!
Havok1327
St. Louis, Mo
evmain, thanks it sounds like 4lb, plus whats in the kit, will work just fine.
SteveL, when I asked they told me each kit comes with around 3/4lb of chips.
kwright
West Michigan
Evmain, how do you like the gray color? I'm debating between the gry and taupe, but I have to admit, your gray with chips looks real good.
E
evmain
I really like the gray color. I never thought of any other color. I guess to me concrete is supposed to be somewhat gray. I think I would stay away from the blues and red and so forth. The only other I would consider would be the taupe. I also have a concrete driveway in front of my garage and I think it blends in better. Good luck.
Dave88LX
York, PA
Excellent info here, thanks for taking the time to answer all the questions. I have another one. :)
I notice you said that you cut-in as you went, and then laid your chips in each section also as you went. I would imagine that as you are broadcasting them, some would land in a section that you had not yet epoxied, so they would be loose on the concrete. Did just leave them there and epoxy over them, or sweep them up, or just give them a quick blow over onto the just-epoxied section?
Thanks. Also, how's it holding up so far?
