Epoxy Coat Floor Pics
ekraft84
Well, I just had my floor done with Epoxy Coat. The results came out great. I couldn't be more happy with it, after doing a great deal of research here on the forums to figure out the best way to go. Christine was a huge help getting everything I needed nailed down - and Dave (the installer) who came and did the work was top-notch as well.
The process included prepping the floor with the grinder the first day, and then priming, crack-filling/sealing, followed by a grey epoxy with black/scone flakes. Dave wanted to ensure bubbling didn't occur after the primer, so he was going to come back out that night to sand if needed, but fortunately with my concrete, that wasn't an issue.
I have a motorcycle lift table going in the garage and Dave was great, matching the epoxy color exactly to the color of the lift-table. Finally after the epoxy had about 24 hours to set, he applied a clear-coat with a fine anti-slip, which you can see in the latter photos. I plan to wait a good 2-3 days before rolling anything on it, and probably a week at minimum before getting a car on there (if I even let cars on it now. :) ).
I had done epoxy at my previous house myself and while it didn't come out bad, it didn't come out great either. To me it was worth having it done right and I'm really happy with the results.
Thanks again to Epoxy Coat for their great work. As an added bonus, I have a nice little box/kit with spare epoxy and tools if I need to do touch ups in the future. All the good reviews I had read here on the forum held true and I would certainly recommend Epoxy Coat to others in the future.
Note, excuse the photo quality as these were taken with my phone without great lighting.
forced induction
Wow, that looks great. I love the way it came out. I have been contemplating doing an Epoxy floor myself or having it done. I am leaning towards the latter as you suggested.
What size is your garage and what was the installed cost if I can ask that.
rugerlady
So glad you love your floor. This is the kind of experience I want all my customers to have! It does look awesome!
LegacyIndustrial
deerfield, IL
They walk the floor with a bucket of chips under arm.
They throw small pinches into the air and let gravity take over.
They also keep more than they will need in case they need it.
Better to go over 2-3 times with the flake than dump too much on at one time.
E
ekraft84
Also FWIW, I would highly recommend doing the primer layer beforehand. Been seeing that topic come up in a few other threads.
CNGsaves
KS and OK
Beautiful job . . . great outcome!
Few questions:
1) What is pit in garage?
2) Looks like you even epoxy coated the stairs into the house?
3) Any special advice on getting the anti-slip just right? Same treatment on the stairs?
4) Can the pros recommend best time of year to apply similar floor if temperature or humidity needs to be just right?
Thanks ... hope to someday do my garage as well.
E
ekraft84
Few questions:
Just saw this. Sorry for the delay.
1) It's a motorcycle lift pit.
2) Yes, did those too.
3) The guy who did it added a certain amount he felt appropriate. He even added a little more on the stairs and higher-traffic areas. It will wear down after time, so I don't think a little more is a bad idea.
4) Not sure the best, but I think spring/summer is usually good timing.
