Epoxy-coat long term results
woohoo
Hi everyone - new to the forum and I'm putting in a 30x40 garage that I'd like to put an epoxy floor on. After perusing this forum, it seems that Epoxy-Coat seems to be the consensus favorite. (Over muscle gloss and u coat it). How has everyone's long term experience been with Epoxy-Coat? Is it any more difficult to use/apply than the others? Would you use it again? I'm only planning on doing this once, so I want to do it right!
snorvet
Northern Illinois
I'm happy with my results from Epoxy-Coat done in May, 2006. I had to touchup a few spots that didnt harden. Epoxy-Coat said I didnt mix it good enough. I would use it again if I had an area small enough where I could handle the short pot-life
W
woohoo
How large an area did you coat? Were the difficulties you experienced just the result of mixing too much at one time, or were there other factors?
snorvet
Northern Illinois
I coated 22' x 24' at about 50 degrees which really wasnt too much of a problem to keep a wet edge at that temp. I did the garage in about 6 mixes.
I did get a touch-up kit to redo about 6 areas each about 3" in diameter. It was about 75 degrees when I did the touch-up and the epoxy got rock hard in the bucket in about 15 minutes. i don't know if this was due to it being a touch-up kit or the heat.
I don't want to take a chance with pot life on my attached garage at 32' x 30' being 80 degrees out so I'm going with H&C silicon acrylic sealer
PontiacFan
I did a 22'x24' section on new concrete in the garage addition about 5 years ago, & it still looks excellent.
I also used it on the old section of the floor, but have had a couple small areas about 6" in diameter peel up. Scraped up all the loose stuf, & patched it. It still looks good, but you can tell it's a patch.
New concrete, excellent result.
Old concrete, better prep next time might help.
