Epoxy-coat min/max time between Base and Clear Coat
TheRealMcCory1
North Alabama
Hey guys. Wife and I put down the base coat of Epoxy-Coat this morning at 11:30. (Not a great idea as temps rose and made a few bubbles which I can doctor up as needed - - but that's not my question)
Onto my question, it's 86 degrees right now so the coating is curing very quickly, I can make only a small mark with my fingernail.
Should I put down the clear coat at midnight or so tonight or would it be better to come home during work and do it mid-morning (again, when the temps are still rising)?
Sorry if typos, wife is yelling at me to reward her by taking her to get ice cream..
Thanks guys,
Cory
T
TheRealMcCory1
North Alabama
Back from ice cream. Wanted to be more clear...
#1. I've read that you should wait 12 hrs before applying 2nd coat. Does this "2nd coat" apply to clear coat as well?
#2. I've read that if you wait beyond 24 hrs you should rough up the surface before applying the 2nd coat. Does this apply to clear coat?
#3. Finally if #2 is true, would flakes (like in my pic) count for the "roughed up" surface?
Thanks folks,
Cory
LegacyIndustrial
deerfield, IL
Cory:
You have 24 hours to add the next coat, once the initial coat has tacked off.
If you go beyond, the flakes will not aid a connection between the base and the clear.
The floor will have to be scuffed and solvent wiped, in which case the flakes become a PIA.
