epoxy-coat prep. question
evmain
I am getting ready to coat a 30 X 40 garage with a lift with epoxy-coat. My concrete is very hard. This is what I have done to prep it. I rented an Edco grinder with stones, not diamonds. I ground over it 4 or 5 times. I made a lot of dust but barely scratched the surface it seems. I vaccumed it up and then acid-washed it with the prep from Epoxy-Coat as directed. It only foamed for about 30 seconds. Some areas I did 2 or 3 times. Then I applied the baking soda as they directed, scrubbed and then power washed at 3100 psi. It is drying and it very clean, but does not feel as rough as I had hoped. Is the cleaniness or the roughness the most important? It is Saturday and the company is closed. I wanted to coat it first thing Monday morning to avoid some heat.
Also, I have a fairly large crack that needs filled. I know they told me to use an acrylic adhesive, but there are a few places that are too large for caulk. Any ideas what type of filler to use.
Just joined the list, outstanding!
Thanks for any help
Eddie
Hammerdown
The Motor City
maybe too late- but if the crack is large use a foam backer rod (Quickcrete makes it) and a 100% solids epoxy patch for the crack. Caulk the backer rod into the crack to fill mopst of the gap and then use the patching compound to create a smoother surface.
