Getting ready to apply Epoxy Coat to my floor and I have a few questions, any help would be great, thanks.
1. I used a Edco grinder to grind the floor, do I need to use the floor prep to etch the floor?
2. If I use the floor prep, I can't use a hose or power washer because I have Sheetrock walls and no place for the water to go, can I mop it up with water?
3. I used a Concrete crack sealer on the cracks and holes to make the floor smooth, is there any issues with applying Epoxy coat on top of that stuff? I believe it's a polyurethane sealer.
4. Should I mop the floor to get the dust off or use the power blower before applying the Epoxy Coat?
5. I have a boarder at the door and plan to tape it off, how long should I wait to remove the tape after I apply the Epoxy coat?
6. Is there a better way to make a boarder without tape?
7. Once I apply the Epoxy Coat and flakes, how long should I wait before I can apply the clear coat?
8. Once I apply the clear coat, how long does it need to set up completely?
Thanks for the help and input on this, I've been looking forward to getting the floor done for a long time.
