Iseman
I put down my Epoxy-Coat Thursday morning (over VCT). Looks good but I have several small areas that won't dry. Small being several softball sized areas and one area the size of 2 tiles all in the last batch of mix. All just inside the garage door. No pictures of the bad areas yet. It may be my fault, I used lacquer thinner to clean some drops of epoxy on the tiles. The epoxy coat instuctions said you could use Xylene thinner to clean up. Do you think this may be the culprit, I thought the Lacquer thinner would evaporate faster and leave no residue. Can I sand these areas out and apply another coat without it looking like ****? I will call Epoxy-Coat on Monday but would like your guys advice. Your help is appreciated
