Epoxy coating steel workbench top
AmericanMechanic
Hi, anyone have experience with an epoxy-coated steel work surface? Wondering how it might hold up to heavy work, welding, etc. Would like to have something like a light gray or white, but anything that would stay rust-free and be easy to keep clean would be awesome!
We used it on floors at my last place, and certain brands would actually burn from weld spatter. Don’t know what has changed in twenty years.
matt_i
One issue is that most epoxies are nonconductive. So you can't just toss a part on the bench and weld on it. No problem for a big tube frame but if you're trying to fix a hub on a 1" OD gear then it could be, trying to get the ground clamp on that.
I would also worry about hammering anything on it.
For some numbers...epoxy is around a 5000 psi tensile substance while steel is minimum 36,000psi and usually more these days.
Mr_B
Reading
i wouldn't consider it
natural finish with a oil or wax & put it to work .
