Epoxy Floor Choice??
CRC57
In the next couple weeks I am going be ready to put a coating on my garage floor. This is a new floor that is aprox 6 months old and has had nothing on it except for stuff from the building construction.
From a diy installer and user point of view, what is my best choice for an epoxy floor coating. I do race car fabrication and repair work mostly. Engine builds, engine removal and install, chassis fabrication, welding, torching, etc. What floor coating will be the best bang for the buck. Or, will none of them be able to withstand the abuse. Thanks
SC-Eric
Spartanburg, SC
Hi CRC57,
Our products are regularly used to coat areas that get a lot more abuse than what you are describing. I would suggest talking to Fred at AlphaGarage so he can help you with your exact needs. I would think that you would need a good 100% solids system. You are going to want to stay away from the cheaper waterbased products that just aren't going to hold up to your kind of abuse. You can reach Fred at: [email protected]
