NewShockerGuy
I am moving in to the new house finally next week.
I am on a pretty tight schedule with work and things being done and delivered to the house so I want to make sure I am being efficient in doing the epoxy floor again.
In the current town house we are in I used muratic acid to prep the floor. I used Legacy products and the floor came out wonderful. I have zero regrets at all. The only thing that I didn't like was that I had to acid etch the floor maybe 3 times at least just to get to the 100grit sand paper feel to the touch.
The new house is a double car garage, roughly 21x21 feet, so abuot 440sq ft'.
My problem is if I have to acid etch the whole floor I feel this is going to take a while...
I called a local shop by me and they are offering this grinder:
http://www.dandbrentals.com/equipment.asp?action=category&category=68&key=GRIND7DUSTFL
They do have other grinders on the site here:
http://www.dandbrentals.com/search.asp?search=grinder
I can get the diamond tipped wheel and dust shield..etc. My problem that I am having is I've never used one of these machines and from what I read here:
"It is all too easy to gouge your garage floor or leave swirl marks in the surface if you are not experienced in the proper use of this equipment. "
Now obviously I don't want gouges in the floor... with the above machine how likely is that.
I don't want to mess up the floor by grinding because it's recommended over acid etching and better... and then have more of a mess or f up to deal with because of lack of experience...etc.
Again I had zero issues with acid etching the first time and it came out perfect when I was doing it.. just took longer because of the time involved to spray it, and COMPLETLY remove the salts and what not...
Thanks,
-Nigel
Thanks,
-Nigel
