Epoxy floor has tire tracks
Al from NC
I recently epoxy painted my garage floor with Sherman Williams H&C Interior Shield Crete and used 2 coats top coat. I started with roughing up the concrete slab and washed down as instructed with the provided product and gave the proper amount of drying time. From start to finish I followed the instructions and the installation after I was done looked really good. After I pulled the car out I saw tire marks on the garage floor, since then it's only got worse. Sherman Williams looked and advised me to get a stripper and remove the marks then use a different sealer where I park the car. I was temped to do this on the long weekend but I'm too disgusted that its only going to get worse.
Has anyone had a similar situation?
Armorpoxy
Perhaps you didn't wait long enough for the coating to cure which can take up to a week or more depending on conditions?
Certain tire compounds can stain coatings too due to additives. We have seen garages that were coated with all of the same materials but one side stained and the other didn't. Unfortunately if your tires have these additives this may be a difficult problem to solve. Use of a 'busy' floor with heavy or full broadcast would tend to hide this.
A
Al from NC
Thank you for replies I sent an email directly to Armorpoxy with the details I'll follow up with what I decide to do and post progress photos.
Thank you
Al
LegacyIndustrial
deerfield, IL
Shea is right, the WB acrylics are more likely to have this occur.
Tires also play a big role. The more "sticky" the more likely it will occur.
