Bklinn
I just finished wet grinding (yes I just read that dry grinding was preferred) and there are some swirl marks that I just noticed after washing the floor. I used a machine from a local rental shop with diamond blocks. Will these grind marks show through on Metallic epoxy floor in a basement? Also, the other photo is of the floor after hand grinding some crack repairs with a 4.5 in diamabrush hand grinder. It seems that the diamabrush got down further and the other parts of the floor are still darker. Should I grind the rest of the floor again with the larger diamabrush that can be rented from Home Depot?
