Epoxy floor snag - unexpected moisture spots
Trrexhouse
I have been getting ready to start a floor prep. Removing all my junk and finding a place for everything else has been a challenge. I did the low cost moisture test with plastic taped to the floor for 48 hours ; dry as a bone. This past week we had a full day of rain. When I got home that evening I noticed wet spots on the floor. Not wet to the touch but what I can only describe as moisture spots. The next day they were gone. I never noticed this before but to be honest I never looked till now. There were no cars in the garage so the water didnt come from outside. Nor did it trickle in . I live 2 blocks away from a canal so my water table is low.
I want to know if I should address this before doing my epoxy job. Or maybe I should do the job on a dry day and forget it . Will this moisture thing affect the floor once it has cured? Any suggestions? Thanks
thegarageguy
More than likely you have a high rate of gas vapor emitting through your slab. A calcium chloride test will determine the existing amount. Anything above 3% per 1000 sqft per 24 hrs is not recommended by any or most manufacturers.
The solution is a negative side vapor barrier, then your preferred epoxy poly system
LegacyIndustrial
deerfield, IL
As GarageGuy mentioned you can do the more accurate test, you may still want to stick with a water-BORNE epoxy system, less likely to have issue with a little water vapor. If you live that close to a water source you should have a high-water table. High-water table meaning you have ground water close to the slab, low water-table meaning far from the slab. Unless you meant something else??
T
Trrexhouse
Yes, sorry I mis typed . I meant high water table. I am going to do the calcium chloride test. That picture looks horrible. Think I'll have a stroke if my floor looks like that after all that work ! Thanks Tim
thegarageguy
I've had much worse....imagine 2000 sqft of continuous bumps and blisters like that....so bad I was embarrassed to take pics...it's a nightmare
T
Trrexhouse
I ordered a 3-pak of cacl test . Should I test as soon as I get them or during another day when rain is expected? The moisture spots were only visible when it rained so I figured testing during rain would make sense. Thanks, Tim
