Epoxy Flooring Projects At Winter: How To Make Them Possible
epoxyboss
Here is a straightforward fact: Epoxy flooring can be installed any time of the year. But one must understand that epoxy flooring installations during winter are more challenging and complicated compared to those that are done during summer. Applying epoxy coating on floors can be DIY’ed using the right tools and techniques. However, during these cold winter months, calling in expert contractors might be the best solution due to their expertise in handling complicated winterized epoxy flooring projects. Either way, it still goes to show that it is possible to install epoxy flooring during winter, but with a catch.
When it comes to winterized epoxy flooring projects, it is possible to get exceptional results under the right conditions. The most important factor when installing epoxy floor coatings during winter is ensuring the warm temperature on the project site. Prior to the start of the project, epoxy resins, hardeners and other products are stored in a room or cabinet with a temperature of 18-26 °C. This is to prevent crystallization in the epoxy resin side of the coating. In case of crystallization, one can reheat the epoxy resin at 65 °C before adding it to the epoxy flooring mixture. Aside from this, the underfloor temperature, as well as the room temperature, must be at least 13-21 °C before starting any epoxy flooring project. This temperature must also be maintained during the timeframe of the project, which also includes the time required for the epoxy to cure. The absence of a warm underfloor and room temperature can result in an epoxy floor that is not 100% cured; one that lacks the durable and versatile qualities an epoxy flooring must-have. Therefore, one must achieve the optimal temperature to ensure the success of any epoxy flooring project. Despite this, it is still possible to get the best results by means of reapplying the epoxy coating on top of the first application.
In conclusion, epoxy flooring projects can be done under the right conditions. Some of these projects may take time due to weather conditions, it still goes to show that they can be done. One can also get the best results through reapplication. Yes, winterized epoxy flooring projects can be challenging, complicated and time-consuming. However, with the right knowledge and proper preparations, one can achieve great results for their floors. Whether a project is DIY’ed or done by professional contractors, having sufficient knowledge on how to execute epoxy flooring projects during winter is crucial in order to make it possible and successful.
E
epoxyboss
EpoxyLineage
Hi EpoxyBoss, I wanted to ask you a question about doing garage epoxy. I'm still new and reading up a lot of the information to get started for laying out my garage. But I've been reading how I needed a grinder or a blastrac? So in terms of the process, I would grind out the garage floor first, and then I would blue tape the areas that I don't want the epoxy to touch. But I'm still unsure of the process afterwards with which epoxy to use or mix first. Do you mind giving me information about that? Thank you.
Armorpoxy
Hi, we have a lot of info on our website about installing garage floors including some videos. It's very easy and we have sold to thousands of GJ users over the years. Feel free to reach out to us directly at [email protected] for assistance, quotes, etc.
LegacyIndustrial
deerfield, IL
A warm floor during winter does not mean it's all warm.
In really cold weather, the few inches before your concrete-wall will likely be cold still as well as door openings.
If you go for it, make sure your temps are good at these areas or you will have GOO!!
Ask me how I know.
Armorpoxy
Legacy is spot on. We have seen MANY gooey messes from door edges and such which are not able to be kept warm enough to cure epoxy.
