Epoxy Flooring
Eccentricson
I have a Rustoleum Epoxy Flooring kit from Home Depot. Unfortunately, I've let it sit in the garage for about 2 years now, and our summers reach about 110-115 outside. Is this kit still good to use?
Thanks,
Nick
AWoodwell
Phoenix, AZ
Sounds like you're a fellow Arizonan! In my experience, 2 years is about the upper shelf life of most paints in my garage. I think its relatively easy to tell though. If you really agitate the can(with a jiffy mixer or something like that), are there any solids that won't easily mix into the solution? In other words, after a good mixing, is there still solid stuff at the bottom of the can? If so, I think you're out of luck.
bdamico
You're in luck. The rustoleum kit was not good to begin with. Save yourself some time and effort, and search here and get a better flooring option.
AWoodwell
Phoenix, AZ
I was thinking the same thing, but didn't want to insult the OP by telling him his product was junk, instead focusing on the actual question.
bdamico
Forget insults. I'd be thankful if someone would help me out in that fashion. Lots of people come here asking questions about epoxy and end up being steered towards porcelain for example--just the nature of trying to help people learn.
OP--you're in luck to find this place. Take your time, spend a day reading flooring threads and inform yourself about what's best for you given how much you want to spend and what you have already (shoot you may have rust prof which may be ok)
E
Eccentricson
HAH! Thanks! I'll do some research around here and see what I can find. I'm not looking for anything expensive, the kit was $100...
Not insulted at all, I bought it when I first bought my house and thought "O a fun project!". Little did I know, how much work I had ahead of me before I even thought about the garage!
AWoodwell
Phoenix, AZ
touche!
bdamico
Ok. so read up on proper prep, that will be key to longer term success. also consider spending some more money on a top clear coat and/or primer. I don't know much about interaction of those with your kit but others certainly do here.
pauloman
it should be fine, but keep in mind that it is very low end epoxy to start with.
dandan111
Indiana
Still new in the box? Trade it in at lowes for a new one/be creative.Rustoleum is a good kit. You want the professional series kit.
Shea
California
Here is an article about the realities of a store bought epoxy paint kit. Pauloman is right about it being a low-end kit, but if you know what to expect from it before you put it down then you will be better off. If you spring to add a clear top coat it will really help the endurance of your coating.
dandan111
Indiana
Everybody keeps saying junk,low end. What's low end about it the cost? Thickness, durability? Have you used the product? Go on amazon.com and read the reviews.
It's not the most expensive if thats your gage..
tobiasa
Flooring plays a major role in the interior design aspect of a building. It is the most used part of any home or factory and requires careful choice. Thus it requires the right blend of beauty, personality, and practicality to meet all the customer's demands.
Shea
California
I don't think you read the article. There is a reason it costs less. One of these reasons is that most of these kits are only a little over 20% solids by weight. That means 80% of the initial film thickness when put down is going to evaporate once it cures. What you end up with is a coating that is only 3 to 4 mils thick and it referred to many times as paint. Using Rustoleum as an example, their 100% solids epoxy is 16 mils thick. When applied to a properly prepared floor, there is no comparison between the two in terms of durability and wear. And we are only comparing 1 coat. What if there were two?
That said, there is a market for the $69 epoxy paint kits. That's why they sell so well. They do OK for the average homeowner who has a low traffic garage floor and wants something down that is easy to clean, will resist stains, and looks good. Plus, they are easy to apply and have a much longer pot life than 100% solids. Will they last a long time? No, maybe 4 to 5 years depending on the circumstances. Some will peel in spots within a year from hot tire pickup. Many don't last more than a year because of poor prep. If you dig around a little you will find many unhappy people who use these. If your floor was prepped well and you spring for the optional clear top coat you might stretch it out a little farther and get a nice shine to go along with it.
That is why some people refer to these kits as junk. However, if you are on a tight budget and want something to put down that will last longer than paint, they are an attractive alternative for the price.
hofiveo
Not me, it was the guy above my post but it looks like the Mods took it down.
Sam3251010
Agreed Shea, I've always heard similar things about a DIY Kit. Sure they are a great way to save money and do it yourself, but when you consider the long term benefits of the alternative there is no comparison. It also depends on what you want to accomplish in the garage. For some, it is just a garage and they are sick of looking at the stains, for others they are looking for something to showcase their garage and turn it into more of a living space than a garage.
