Recap -
Had a crappy painted floor from the previous owner - probably @15 years old.
I used a Bosch hand grinder and edger to prep the floor
Used Legacy HD-105 to fill spalls
Used Armorclad primer - 2 gallons
Used Armorclad 100% solids epoxy and topcoat
Lessons Learned =
- Hand grinder (the Bosch unit is excellent), while a cheap alternative, requires a good vacuum system (I used a dust deputy) and respirator. End result is fine for residential garage floors, but certainly not for showroom floors. Had numerous swirl marks, etc. there were mostly covered or hidden by the epoxy / flakes. Again, the final product looks great for a residential garage. I got lucky perhaps where the concrete was soft, allowing me the fly thru the hand grind - this may have also contributed to aggressive removal of areas as well.
- My biggest problem was knowing how much primer / epoxy to use per section without running out in the end. Unfortunately I was light on the highest traffic areas whereas other areas where it was thick looked great. If I did it again...I would doubleup on primer or get an extra gallon of Epoxy (whichever was cheaper)
- Have your wife spread the flakes. Now she cannot give me any $hit if they do not look even or appropriate. This was my best move.
Final question = Was it worth it to hand grind or should I have spent the money to hire someone?
It was certainly worth my effort to hand grind. Best quote I got was $1k for someone to come out and do the grind...In the end, I spent about $200 on my grind (taking into account what I will recoup from the tools purchased if/when I sell them).
Total cost was way over what I wanted to spend, but I went for quality and 'do it once' vs going cheap with questionable longevity. Omit the grinding costs...
While the kit was $460 (plus shipping), there were additional hidden costs
1) Primer (pretty much a necessity if grinding, eliminates outgassing as well) +$160
{If you go for a nicer thick coat - add another primer kit (+$160) or another 300 sq ft of Epoxy (+$180)}
2) Patch repair / spall repair +$60, go with the good stuff, do not get Home Depot stuff
3) Extra prep tools, buckets, brushes, doodads +$50
or an extra $270-$450
Bringing total Epoxy cost to $730 - $910 (DIY)
Pictures of the final product
And a video of the floor after each stage <you can see the end result imperfections better here>
http://vimeo.com/38446505
Lessons Learned =
