Epoxy on broom finish
sandwich
First post here...
I've been reading a lot about epoxy flooring. My garage currently has a broom finish, does this need to be ground smooth before applying an epoxy?
Also looking at RaceDeck, anyone else in Canada using RaceDeck or some variant?
Cabby89
It is best to grind it smooth or you could overlay the floor to a smooth finish.
TheShrine
Texas Hill Country
Everyone wants to grind the floor before epoxy...why,....to ensure a surface that the end product will adhere to.
I'm thinking a broomed surface would more than ensure adherence. Depending on the "broomed-ness" I'd think it would work fine. Of course excessively deep broom groves might prove a challenge to wipe up some spills.
My $0.02 worth.
Motofixxer
You would likely have a coverage issue too. The squeegee would run over the high ridges and leave the epoxy in the lower valleys giving your floor a funny looking finish I think. The high ridges would be concrete while the rest would be smooth and glossy. Unless you used a lot of epoxy and laid a thick layer. I would vote for grinding it down.
ssathre
Northwest Iowa
I was told by christine @ epoxy-coat that a light broom finish is what I should tell my concrete guy. this way the epoxy has something to bond to.
rugerlady
Depending on how rough the broom finish is, it may take alot of epoxy to fill the voids or ridges if it is not diamond ground.
Motofixxer
Curing time depends on temps, thickness, how well you followed and mixed the 2 parts for proper proportions. Generally it's walkable the next day, and ready for vehicle traffic in 2 days. Although that is general, I would wait a few days for anything other than stocking foot traffic. I have followed a lot of directions that weren't exactly accurate.
