passinthru
Hi all, will epoxy work on a 3/4 T&G OSB attic floor. Very hot in summer and cold in winter. I'am planning on keeping my rideing mowers and such up there and need to protect my floor some how.
Thanks
Thanks
unless you mean put it on alot thinner?Don't cheap out on the epoxy. Use a 100% solids. You can go with a pigmented epoxy or, if the surface of the OSB looks good, consider a clear 100% solids epoxy. It will highlight the wood grains, textures and give an unique finish. Another thing, pigmented epoxies normally cost a couple bucks more on the gallon. Your call, Good luck.
dcs Inc
Would your E100-uv1 be what I would be looking for?
Thanks
