I have a ~50 year old 600 sq. ft. garage I am renovating and leaving the floor for my final project.
The slab isn't in terrible shape but has some long cracks, divots, and spalling.
I have found a local company willing to perform the diamond grinding and patch repair for around $1/ft. Figured this was best to pay out since it'd cost me half that to rent the grinder alone.
This is a property I only plan to live in for 4-5 years. I'm looking for a good product that will be easy to clean and still be in pristine condition after 5 years. No 'heavy duty' work will be done in the garage. Cars will be parked there and normal household renovation projects will be worked on in the garage.
My numerous hours of research led me to these 3 epoxy/polyurea-based products that are currently in the running.
Just recently I came across sealers/densifiers as a cheaper alternative to epoxy floors that may be better suited for surfaces that won't get a ton of wear-and-tear.
Sealers/Densifier solutions researched:
Euco Diamond Hard
H&C Colortop
My two primary questions for the community here are:
1. Can an old floor be rehabbed with a diamond grinder and patch work well enough to where a sealer/densifier will actually look good? Or are these typically only used for new slabs?
2. Will I be happier spending the extra money to go with an epoxy/polyurea system instead?
- Wolverine Epoxy coating system
- Legacy Industrial Nohr-S
- Sherwin Williams Armorseal 8100 (recommended 3 coats + polyurethane topcoat)
Euco Diamond Hard
H&C Colortop
