Hi guys, first post/question.
I decided to epoxy my garage floor which has previously been painted and bought a Rustoleom solvent based kit. I'm not sure what paint was used on the floor.
First issue: the old paint is chipping away pretty easy with a razor, so I assume I need to remove all the old paint.
2nd issue: after scraping some of the old paint, I noticed the concrete is very smooth, shiny and brown in color. (The brown I believe is normal as all the concrete inside the house is brown too) But I'm now assuming the concrete was sealed. I put water on it and it doesn't soak in.
So ... Has anyone painted over sealed concrete? I've been searching the web for days and have read different stories. Some say you have to diamond grind, some say to just rent a sander and rough it up.
My plan is to rent a sander and rough it with 80 grit then possibly acid etch then apply epoxy.
Also wondering if there is a primer that will adhere to sealed concrete.
Thanks for any past experience/advice.
