We purchased a home built in the 70s, and the garage floor is covered with what appears to be large linoleum stick on sheets, appears to be 2 sheets for the 2 car garage. Overall condition is pretty good - some stains here and there, and a few small edges where the linoleum has come off but is not lifting.
I'm looking to epoxy the floors, and would like to epoxy OVER the existing linoleum. The linoleum appears to be glued to the floor very well, and I do not want to go through the labor/process of grinding off all the residue.
My searching has turned up this old thread:
http://www.garagejournal.com/forum/showthread.php?p=2583235
Only difference is instead of linoleum "tiles", its linoleum sheets. I just want to confirm that the process described in the old thread to "Degrease it, scuff it, solvent wipe, 100% solids flexible primer, 100% solids topcoat." still applies.
If it's okay to put epoxy over linoleum, my next questions:
1. What do I use to "patch" the small areas where the linoleum ripped off? It is not exposed concrete underneath - rather the remnants of the glue
2. Best way to scuff/sand the linoleum? I have a Dual Action polisher, so I can always get some sanding pads, but it might take awhile to do by hand. I've read somewhere not to use a belt sander - any other DIY machines I should look into renting?
Thanks for any advice/help.
