Epoxy primer concern
mntbkrguy
NoVA
Hello I just painted the garage floor with the Legacy Industrial "Standard Epoxy Primer Coating" in preparation for their Nohr-s coating.
My problem is in one small section all these spots are showing up.
What is causing this? Should I be concerned? Does is need a second coat of primer after the first dries? (I still have a half gallon ready to mix if more is needed)
Help is really appreciated.
Sent from my SM-G892A using Tapatalk
Shea
California
This is a great example why primers can be good to use. They are called the ugly coat for a reason. I would suggest giving Legacy a call and email them the pic while you are still in the recoat window (hopefully). It looks like there was a contaminant in the concrete that caused that reaction. It's hard to tell from the pic.
mntbkrguy
NoVA
Thank you, I will see if I can reach them. Fortunately as it dries it's looking better. I can only imagine how disappointed is be if this was on the primary coat.
Kaizen
New England
Looks like oil. Even if that looks good I’d worry about it lifting
mntbkrguy
NoVA
I decided to just continue moving forward. Luckily it's in a spot where it would be difficult to drive on if I tried and with the flakes you have to look very closely to see anything. I think the primer took the blunt of the impact. With the black and grey flakes you can't see anything wrong with it.
In the end I coated the floor for protection and ease of cleanup not for a showroom finish.
Jwithing1
STL
Did you grind or etch? Let us know how it turns out. Going to coat in a week and a half if all goes well and would like to know how to proceed if I run into this problem.
