Epoxy questions - new floor
Wuaname
Florida
I have been doing a lot of reading through the archive and have come up with some questions of my own . It will be primarily for my motorcycles, no car will be in there. I will need to the floor to withstand the basic garage issues; oil, gas, grease, etc. I don’t know if I am going to sprinkle chips on it. It is a one car garage; about 240 sq ft. Should a one garage kit be fine?
Color looks like it will be white or some other gray or light color (no tan). I want it easy to spot a bolt / nut that might fall on occasion to the floor, but I don’t want it looking like some factory floor. I see some issues with the cleaning of white epoxy floors, wonder if maybe I will have fewer issues since it’s just the motorcycle, & no salt/ snow to deal with. How will pigmented urethane help with this?
When it comes to brands Legacy I’ve read on here that it is good, but does it use primer? I want primer on my garage. Epoxy-Coat doesn’t use primer and no urethane topcoat I believe, correct? So what alternative, if I can’t use either one of these? Rustoleum I haven’t read much good on, so that option is out and so are any box store brands.
These seem to be the general steps I have seen on here, which I am going to follow. Welcome to any corrections or comments.
1. Etch concrete (acid wash) – allow the concrete to sufficiently dry out.
2. Epoxy coat (primer coat)
3. Basecoat epoxy and color chips – allow to cure overnight
4. Urethane clear coat (topcoat) –
  • I want to have minimal issues with the floor being slippery. Anything different I should do for this?
  • How many times to should I do the acid wash?
  • Can someone break down the cleaning further? Wash the garage with water and soap? Before / after the acid wash or just after? Remember, new garage. What it will have I am sure, is a lot of dust from the construction.
  • How long should I wait in between coats?
jaye944
GTA, Ontario, Canada
I'm doing exactly what your planning, although, I'm not using chips, and the urethane coat is not clear but tinted the same color as my base coat. I'm using Armorcoat
A_Pmech
IL
*shrugs*
I used the Rustoleum stuff and it's worked very well for me.
Falcon67
Merkel, TX
I used something from Lowes on the first shop floor and it's still good 15 years later. However, your chances of success are much greater with a known quality product. Good prep is the thing. I used some cheap-o not 100% epoxy on the new shop because of budget reasons and thanks to careful prep on bare cured concrete it's holding up really well. And I don't treat it nice - weld on it, park leaking things on it, drag 80 lb benches around, floor jacks, jack stands, etc.
Of your 1-2-3-4, I only used 1 and 3 on both shops. I don't care for a top coat and got no time for a primer. Not that you should not - but for my stuff the epoxy bites into the floor well enough by its self. I'm sure a primer would be even better.
As for slippery - watch your spills. I use stuff like this in most work areas.
http://www.rubberflooringinc.com/interlocking-tile/foam/58-diamond-soft-tile.html
On the acid wash, I mixed muratic 1:4 gallons water. I mopped it, then rinsed and dried, then used lights/the sun to look for any shiny spots. The plan was to have a dull finish all across the floor to be sure there was grip everywhere. Not a heavy etch, jsut enough to take off the shine. I actually mopped it three times - once with a non-acid floor etch (waste of time) then twice with the acid. 4:1 neutralizes pretty quick on a floor. Fizz doesn't last very long at all. And keep it moving.
W
Wuaname
Florida
I looked at your links but damnn that looks expensive lol
DocHolliday
Magnolia, TX
I just want to follow this thread. I've been a member here for a long time, but don't post much. But, I also have the same questions. I am in the finishing stages of 24' x 16' workshop, and trying to decide on floor coating. In my case it will only be a workshop. The plan is to move all of my fabrication equipment (welder, table saw, miter saw, grinder, etc) out of the garage to have room for automotive projects there.
