Arkive
I've seen pictures so I know you can but looking for insight/tips. Namely curious about preparing the surface. While the slab has a vapor barrier, do I need to worry about moisture wicking in through the cinderblocks? If so, should you paint/prime the stem wall with something first to create a moisture barrier before the epoxy primer/application? Also curious about whether you fill in the mortar joints between the blocks (as those are curved in per the norm). And if so, with what? More mortar? Would a bead that thin adhere properly or are you better off with a caulk product?
Basically, just looking for do/don'ts in this regard. Thanks!
