Epoxy Vendors - Shrinkage Crack Filling
tlmartin84
West Virginia
I would like VENDOR recommendations only. I have read dozens of threads, and there are dozens of products, methods, etc. I have even seen varying responses from the same vendors. Regardless It would just be nice to have one thread with solutions. I have also seen some state that even after prepping and filling there will still be a small crack form.
For normal shrinkage cracks, what do you recommend:
What width crack should you just top coat over?
At what width needs ground out?
What product do you recommend to fill with?
Garage Flooring
Grand Junction, CO
There is not a simple, works in every case answer. A lot of this really truly depends on the products being used.
Generally speaking I will coat over a hairline crack on an older floor.
If I can fit the tip of a knife in the crack but not a whole lot more, I will grind it out and fill it.
If I am using 100% epoxy in a complete system (primer, base coat and top coat) I will push it a little more than I might with say Rust Bullet or even a polyurea.
a GOOD 100% solids filler should NEVER shrink but it may 'slump'. Deep crack, you fill it in, looks level and during the cure sinks into the crack a little more. Multiple methods to deal with this.
Crack filler and joint filler are NOT the same. Make sure you are using the right product in the right areas.
