Equipment
JMoriner
I will be stripping off a messed up paint job. I will getting equipment from Sunbelt Rentals. I am assuming a two disc grinder will be enough. They applied generic paint and some primer to the floor. Is an edging tool a serious necessity or a luxury? We have a lot of lifts and equipment in our shop.
LegacyIndustrial
deerfield, IL
J:
You want a grinder that has diamond heads. (Edco Dymaserts is one option).
You will need a 4 1/2" or 7" grinder for the corners, edges and around the lifts.
You can't count on the original coating staying down.
Boygoesbig
Based on the sound of your job a grinder with a good vacuum set up is a must. And Legacy is right, you will want a grinder that uses diamond heads.
Cosmic_Monkey
Hi JMoriner,
I rented a single disc grinder from Sunbelt a couple of weekends ago. Great bunch of people to work with! See this thread for pictures of the grinder:
http://www.garagejournal.com/forum/showthread.php?t=125318
I had to also rent the 'Dyma-Serts' - you have to have three for the single disc and 6 for the double. You can see them installed on the machine held in with wooden chocks (that come with the rental).
I found the single disc pretty easy to work with. It took me about 4-5 hours to do a single pass over ~1000sqft. The following day I brushed the whole floor and concentrated on the bits I had missed, the edges and low spots (another 3-4 hours). I rented one of their shop vacs as well, which had some effect but not much - most of the dust seems to be thrown out radially from the head rather than being sucked up by the vac. I would recommend it though - I had more than a few inches of dust in the vac by the end, but about a trash bag full of dust that was swept up by hand!
I'm not sure about the double disc, but I used a 'side to side' motion with the single disc which seemed to work well. I also had the limitation of being able to lift and transport the thing in the back of a station wagon.
I managed to get pretty close to the edges (within 1-2"?) with the single disc. My floor had a build up of concrete at the edges which meant the head would get caught so I had to be a bit careful. I've been finishing the edges by hand this week (see above thread).
It goes without saying but I made sure I wore a good dust mask, and ear defenders (with ipod, it's pretty monotonous work!) I also wore a hat the second day - that dust gets *everywhere*!!
Good luck - post some pictures when you get around to it.
Cosmic
dlewis
Townsend,De
The reason the grinder was throwing the dust out the sides is because the machine is missing the rubber skirt on the bottom.
Cosmic_Monkey
Ahhh nuts...that would explain it! I had seen other machines on the web with the skirt but just thought the one from Sunbelt was how it came. Too late for me but not for the OP :)
