scooby074
I hope this is the correct section to post this, I suppose lube is a tool
Anybody know what an equivalent to Castle Muscle Grease would be? Castle products are mostly unavailable in my area as far as I can see (never came across them for sale, or at any past employers). There is supposed to be a Canadian distributor in Ontario, but they seem pretty smalltime and there is nothing at all listed for my area.
The description from Castles website says:
Castle® Muscle Grease™ takes over as a lubricant where lithium and calcium grease leave off. The aluminum complex base of Muscle Grease™ enables it to excel in heavy load, extreme pressure situations and over a wide range of temperatures (0° F to 350° F) without melting, hardening, or thinning. It is 100% waterproof and resists corrosion from acids, alkalis, and salt. Muscle Grease™ sprays like a liquid to penetrate, and then sets up as durable grease.
It seems that Eric at SMA swears by the product for rust prevention on rotors and other general lube. Im in the rust belt too, so if it works for him, it should work for me.
I use a lot of Fluid Film, LPS 1 &2, and Rust Check and Loctite Anti Sieze, but the Castle product looks like it applies like FF but has EP lube and anti-corrosion properties too, sort of an all in one, easy to apply product.
It seems more "fluid" than a Moly spray then forms a nice protective gel film for protection..
Looks like a winner, but it is impossible to find. Any equivalent from LPS, Loctite, or Zep? I have access to all those products.
