new to this site...from the HAMB. anway getting ready to build my own detached garage, 18x22, to house my car and the rest of my junk.
need to know if there is a utility that will help me figure out how much lumber/material i need to buy.
thanks
I'm an estimator and there is a three word secret to estimating. It is "Don't forget anything".
The second rule is "A bid is better than an estimated price".
Third is "Define everything completely".
You have labor and materials, taxes, insurance, fees and interest.
Everything has to be bought, transported, stored, installed and cleaned up after. Someone has to do each and every thing. Everything and everybody costs money. Define each task, each item and assign value to them. When you define an item, try to be as specific as possible so the price is as accurate as possible. Write a set of specifications with selections for every item in the job. For items that you just can't decide on, make a selection based on the quality level you expect to get the correct cost.
Big one:
Do the most complete and accurate take off possible. Anything missed will throw off the estimate big time. Do the takeoff from the drawings and specifications and build the project in your mind as you go. You must know every item required to complete each category of the work. For instance, you must know every stick of lumber required for rough and finish carpentry. Oh, and don't forget the rough and finish nails and hardware!
Steps:
!. Sketch of draw up the project to scale.
2. Take off all the material quantities
3. Get all the labor bids.
4. Fill out the entire spreadsheet and total up the costs.
Add a percentage for contingency.
A sample list of codes:
(Put everything that needs to be done or paid for, somewhere)
Here is a link to an extensive list of cost codes arranged by the different divisions. Use this as a guide and eliminate the items that don't apply to your job. Make a spread sheet with the ones that do. You should get within 1% of actual cost.
http://www.powertoolssoftware.com/QBManualMasterCode.html
If you are just trying to do a simple take off or just a rough lumber take off, just let the lumber yard to an itemized one for you.
Bill
