Etching Concete
bsmith95610
I just got done acid washing my garage so that I can apply some Epoxy. Is it ok that I acid washed it today even though I am not going to start rolling on the epoxy until next weekend? I wanted to make sure that it thoroughly dried I just wasn't sure if I waited to long if anything would go wrong.
bsmith95610
I rinsed it out a lot yesterday after I etched it. It seems like the acid never comes out!!! Finally I think I got most of it out. Today I'm going to wash it again though just to make sure.
rugerlady
Once the concrete is etched, you can wait to apply an epoxy. I would either sweep it well or use a leaf blower to blow any dust or debris our of the area before applying.
arcavaexcelia
Cuba
cheap tramadol buy online
Êóïèòü ôóòáîëêó punisher
Ñìåøíûå íàäïèñè íà ìàéêàõ
Ôóòáîëêè frankie morello
Ìèíè ôóòáîëêè
Ôóòáîëêè fruit of the loom
Ôóòáîëêà òîòîðî
Ôóòáîëêè äëÿ ïàðû
Êóïèòü ôóòáîëêó ìàí÷åñòåð þíàéòåä
Àæóðíûå ìàéêè
Ôóòáîëêà stalker
Ïå÷àòü íà ìàéêàõ
Ôóòáîëêè ñ ïðèêîëüíûìè êàðòèíêàìè
Çàêàçàòü ôóòáîëêó
Ôóòáîëêè òóðöèÿ îïò
Ïðàâèëüíûå ôóòáîëêè
Ìàéêà g unit
Ôóòáîëêè áåçðóêàâêè
Ñäåëàòü ìàéêó
Êóïèòü ìàéêó ìîñêâà
Ðîê ôóòáîëêè
Ôóòáîëêè èç òàéëàíäà
Âûêðîéêà ëåòíåé ìàéêè
Ïðîäàæà ôóòáîëîê îïòîì
Ôèîëåòîâàÿ ôóòáîëêà
Ìàéêà god dj
Ôóòáîëêà ñ ìåäâåäåì
Tiesto ôóòáîëêè
Ôóòáîëêè áåçðóêàâêè
Êóïèòü ôóòáîëêó ìèëàí
Ôóòáîëêè xxxl
Åâðîâèäåíèå ôóòáîëêè
Çàáàâíûå ìàéêè
Ôóòáîëêè äëÿ ñóáëèìàöèîííîé ïå÷àòè
Ôóòáîëêè äëÿ ïîäðîñòêîâ
Àäñêèå ìàéêè
Papa roach ôóòáîëêè
Ïðèêîëüíûå ôóòáîëêè ñ æèâîòíûìè
Ôóòáîëêà ÿ ðóññêèé
Ôóòáîëêè óçáåêèñòàí
Ìàãàçèí æåíñêèõ ôóòáîëîê
Ôóòáîëêè íà çàêàç ôóòáîëüíûå
Ïðèíòû íà ôóòáîëêè ñêà÷àòü
Èíòåðíåò ìàãàçèí ôóòáîëîê ñ ÷åðåïàìè
Íàíåñåíèå èçîáðàæåíèÿ íà ìàéêè
Ôóòáîëêè øîðòû
Ôóòáîëêè ñ ëîãîòèïîì
Êóïèòü ôóòáîëêó ôóòáîëêè ïå÷àòü
Äèçàéíû ôóòáîëîê
Ôóòáîëêà ñ äëèííûì ðóêàâîì
Ìàéêè ëó÷
bsmith95610
Ok I'm pretty sure I got most of the acid out of the garage. I sprayed it out with a hose for another hour last night. When I spray the concrete there is still a little bit of solution that comes out but not much at all. Do I need to put down a mineral/acid salt remover to make sure all of the acid is out of there? Or should I be ok as long as there is not much acid still on the concrete.
rugerlady
After triple rinsing the floor, you should not have any acid residue on it. If you do have residue, you should not apply the epoxy until it is completely rinsed off. The acid can act as a contaminant if left on the concrete.
