alwaysFlOoReD
I bought a air heat gun to do some welding to repair tarps. I bought it knowing that the item was 10a/240V. I've done a little household wiring for 240V stoves and welders. But I have no knowledge of how the plugs on an EU device are wired. In the following pic, the top terminal has an "E" beside it, Is that "earth" meaning ground? The other two terminals are labeled "L" and "N". How do I wire a new plug to use power from a generator? Is it wired the same as a welder with two 120V hot lines and a ground?
Pic of plug end I want to cut off and replace;
[/URL][/IMG]
Or can I source an end to make an adapter for the L14-30 outlet on the generator so as not to cut the end off?
Thanks,
Richard
Thanks,
Richard
