We are building a detached garage in Central Indiana. We will have heating in there, likely as an electric furnace with recommendations from others here since we don’t have gas available.
In the summer, we can open the garage doors and person doors to help cool the space, but the attic area, while unfinished, will be a place where we can do varying projects as well I have a store items. There will be typical ridge vents in the roof, and the attic will actually be open to the garage level via standard fixed stairs.
I am looking for a good way to replace hot air in the attic with cooler air from the outside. I have been thinking of some sort of active ventilation through the roof when it gets really hot that we can either activate with a thermostat or a switch. I found one vendor of a attic fan add some unique active venting, but they said in order for it to really work, you wouldn’t want to have the conventional venting that we of course would like to have. In the case that we were to use the space, I would want it to be rather quiet. One possibility I looked at and have not completely ruled out is an exchanger from Panasonic Designed to bring in fresh air regardless of season, which may help. It is unclear if it would provide a material cooling effect or just improve the air generally.
Has anyone done anything like this before and/or have recommendations? Thanks!
