EvaproRust?
J Persons
Louisiana
Does this stuff have a shelf life? I bought some a couple of years ago to clean up some rusty hardware, and it worked fine. Now 2 years later I tried it on some sheet metal dash reinforcements and it doesn't appear to do anything to the rust spots. The product has been sealed in its original container since the last time I used it.
carlaisle
I used some that was over 10 years old and it worked fine, but there's no way to know if they changed the formula over time. I've found parts to be derusted clean up best if they can be submerged.
LeonardY
Southern California
I have some that is well over twenty years old. Still works great. Have you diluted it?
J
J Persons
Louisiana
Update: The steel stamping has been sitting in the Evaporust for seven and a half hours now, and it finally came clean. Took it out, washed it in water and blew it dry with compressed air. I'll powder coat it tomorrow morning. It's something that no one will ever see, unless they take the dash apart, but I just hate rusty sheet metal.
mrhemi426
SW Ontario
I have a 5 gallon pail that I have been using for years, still works great. As others have mentioned, temperature is potentially an issue. My shop is kept at 55-58 deg. in winter. I usually soak the parts for 24 hrs. minimum for best results.
