Ever see a Battery Voltage Go UP after resting
mobiledynamics
Gotham City
Tinkering with the charging system...
Battery charged, rested overnight, V read 12.7
3/4 Mile Drive. Reads 12.4
8 Mile Drives, 3-4 Ignition Cycles later. V on Battery still at 12.42
Walk back to the battery 2 HRS later. Engine has not been on, etc. Battery is reading 12.7
Never seen a suspect battery go UP in V while standing.
Anyone have any insight
Showkey
"MEMBER EMERITUS"
Wausau WI
Sounds like you’ve got battery and or charging system issues.
Is the voltage measuring device reliable and decent quality ?
Type of Vehicle ?
Normal charging voltage is 13.5 to 14.5 for most vehicles. Modern vehicles the charging system is controlled by the ECU.
Normal fully charged static or resting voltage 12.8 volts.
mobiledynamics
Gotham City
Typing this on the phone but during the test drive, alt voltage seemed in check. I do see a momentary dip on decel down to low 12’s but it drops and then climbs back up.
Just wasn’t expected to see the V go up after walking back to it 2 hrs later
rlitman
Long Island
Yeah, batteries can do that. Take a battery off float and put a discharging current on it. The voltage will quickly drop, and then slowly rise back up again. The chemistry reacts more slowly than you'd expect. DC capacitors have a similar issue with polarization.
Did you have it tested with a Midtronics?
mobiledynamics
Gotham City
No idea what they used at AutoZone. They went through the screen, chose battery type and then how many CCA. The tester reported (battery replacement) but aside from that, I have no idea how the tester determines it or how accurate their tester is.
Same tester also ran on alternator. They said it checks out fine.
Still diagnosing. I feel like it's gotta be the ALT but since I started troubleshooting and looking at the V real time, it looks fine when I'm monitoring. However, even with a GOOD battery I have and put it in the same vehicle, I'm still getting gremlins...that sorta point towards the alt. Unless, the alt is dropping the voltage in a nano-second and I'm not seeing this.
Sevenhills1952
Virginia
X2 this explanation, I'm electronic tech. and have seen it happen.
Sent from my SM-S320VL using Tapatalk
Oggy
Central New York
My experience (tech in the army) is that the battery is 90% of the time to blame. We replaced a couple alternators (2) on a Humveee because we had already replaced the batteries, turned out one of them was bad "out of the box."
Ymmv, I would do a load test on a different machine for the battrry, or, if it's close to time, replace it.
Sent from my Pixel 2 XL using The Garage Journal mobile app
850xpeps
A bad battery will drop down when loaded and come back up when no load. Do you have a battery load tester? Basically an element. Hook up and turn switch on and watch needle. If drops to bad battery point then time for a new one.
Vvmvbb
CT
Sounds like fairly typical recovery effect.
https://en.m.wikipedia.org/wiki/Recovery_effect
Might be a little more pronounced if the battery is stratified (i.e. acid has settled to the bottom, water on top), which I think can happen if the battery sits < ~80% charged for a while or never gets a high enough charging voltage.
Using a multimeter, what is the voltage at the battery with engine running?
Ole Slewfoot
Freedom, CA
Or if you have one of those cars that runs some stuff for awhile after you get out, that might drop your 'end of drive' voltage.
