I've had one for about 2 years. Small time fabricator. Works as advertised. Accurate miter cuts.
Not smart enough to define a cold saw, so there's that.
Makes noise but I wear ear plugs when cutting.
Makes chips but I built a stand with side and back shields and a collection chute so it's not too bad.
I've cut mostly A36 mild steel, but also some 304 stainless and some galvanized. I've cut up to 3/8" thick 4" square tube and angle, 5" sched 40 pipe, 6" channel, 3/4" flat bar, 1.5" round bar.
Not sure I've mastered the proper feed rates for miters on thicker stock when the miter is across the flat, as I've bogged it down a bit on 1/4" stainless 4" flat bar and same size galvanized.
I think key has been proper clamping and positioning of the saw blade for a cut (you can lock the saw in one of three positions front to back to get the optimal cutting position for the blade).
I've only used evolution blades thus far, but I'm going to try another brand.
I did bust a couple tooth tips when I did not clamp something adequately. Blade still works.
The one holddown clamp can only be used reasonably on the right side of the saw as it interferes with the motor on the left.
It's a smaller footprint than a horizontal bandsaw, which was a driver for me and it's an upgrade from a portaband saw and table. Aluminum vase vice stamped steel.
It's not cheap.
