Hey fellas,
I'm new here so pardon what may be dumb questions!
Anyway, attached is a jpeg file of what I'm trying show via Acad here
As you can see, there's a downhill slope where I'd like to place an approx 25'x35' size metal building. There is an existing gravel driveway that'll become the driveway in front of this future building. The garage floor will be made of concrete that'll support a 9,000# car lift on one side.
In terms of the concrete pad, I'd like to explore various options that may be available to me but I'm not aware of due to my lack of education on this matter.
The soil in my area is mostly rocky and stable. My elevation is 7,000' and the future metal building will meet the snow/wind loads. I'd make the garage deeper but I think the septic leach field is in that area. I located the septic tanks and they're a safe distance away from the future garage site. My friends are telling me that the excavation/concrete costs will be more than the actual metal building
Questions:
1) Is it possible to build a suspended floor for this project so that I can use the basement as a potential storage area? Mind you, this will be a shallow basement but storage is storage. Can this be done for the load? I ask because I saw this at a friend's house where the floor of his house was made of concrete (painted to look like large tiles) and he had a basement that he used as a wood shop. This is a huge two story log home but the actual basement was small. I assume it's only under the main living room floor where no rooms are built on top.
2) If I had to use traditional excavation means of building the floor, then I assume this entails: pour a stemwall around the perimeter first, back fill the area surrounded by the stemwall, compact the dirt, drive down pilings where the lift will be and finally pour concrete. Is this a valid assumption?
3) any other options I should be considering for the concrete floor? Perhaps a floor made of different material? I like concrete for the ease of the use of creepers, clean up and abuse resistance to metal fabrication, welding, cutting, etc.
4) what are the different style of concrete pouring techniques? I hear something called monolithic pour which sounds to me like one giant slab of concrete.
TIA,
Ash
Questions:
TIA,
Ash
