Excavator Repair/Garage floor
Broadie
SE Alaska
Hopefully this isn't too stupid of a question, but I'f hate to find out the answer the hard way - I need to do some repair work on my Bobcat mini-excavator and was wondering if I can bring it into my garage without doing damage to the slab-heated floor? It's a 7000 lb machine, steel tracks and want to make sure I don't crush the heating system in the slab. My gut tells me I'd be OK, but wanted an "expert" opinion from someone on here.
Thanks!
WD
Bert_
NW Iowa
Zero worries. You probably have at least a 3 1/2" slab which is plenty to support that little machine.
If the concrete has a lip at the door it might get chipped. It's about the worst that could happen.
Ground pressure from a track machine is actually pretty low.
Mikeske
Washington State
Well think about it a 4x4 pickup are running in those ranges of weight with smaller contact to the ground with the tires. I see no problem with what you want to do just remember to get some thick plywood and Bob’s your uncle.
Crawlin
NC
I have a 38k lb steel track excavator and walked it in my shop to have the windows tinted one winter. Layed down 2x6s and no problems other than getting the floor dirty. I do have a 6" slab with radiant heat and epoxy coating. I did not try and turn though, straight in and straight out. Used tires work well too.
finn
The UP, God's country
My shop was originally built by a logger. It has radiant floor heat.
I have scarf marks on the floor, presumably from a crawler.
Funny thing. I needed some trees cut down near the house and power lines, so I called a tree guy, and asked him to stop by the shop and we’d go to the house. He stopped in, and told me he had spent a lot of time in that shop as a mechanic. Last time he was there they had a slasher torn apart with hydraulic fluid everywhere. He had never seen the place so clean and orderly, a concept I can’t grasp, as I consider it a mess most of the time.
A mid sized loader with a slasher probably weighs at least 25000 lb.
johninct
I never scratched my floor with plywood and my Cat 215 ( 20 ton).
racecougar
Missouri
I've been trying to dig up a picture of it inside the shop, but I've been unsuccessful thus far. I guess that's sort of a testament to how rare an occurrence it is. The steel tracks can mar the surface of the floor, particularly if they aren't clean (have mud/rocks stuck to them) and if you have to turn. As others suggested above, if you can lay down some plywood or lumber to run the tracks atop, you're set.
NUTTSGT
Northern Central Ohio
If you don't have any plywood/OSB. I would suggest getting some out of the cheap "defect/damaged" stack at the local big box store.
larry_g
oregon
As said above pay attention to the transition from the drive to the concrete. Me I have a gravel drive and when bringing in a tracked machine I build a bit of a ramp with 2x's to prevent the machine from grabbing just the edge of the concrete at the transition. I also use wood under the tracks to prevent marring the floor.
lg
no neat sig line
