my matco1769a (IR 2135timax) has been run full time work week for 3 years with no problems, just grease it about once a month, put some oil in it now and then and its good, its will break alot of things at 175psi if im not careful, and my other snap on guns have been holding up longer than that, the im6500 i had to rebuild about a year ago, but nothing you wouldnt expect for a gun thats been around for about 10 years now
ive always run mine as high as the compressor can go, at the house its 200 (bought a square d pressure switch that'll let it got that high) shop its 175
also, based on the efficiency of your plumbing, regulator pressure isnt always the presure at the tool, squeeze the trigger and see what the pressure drops to whie holding it, then crank it up to adjust
With what i do, working on 3/4 and 1 ton trucks, with plows etc., you need the most power you can get to take of rusted on bolts, and alot of the time, i stll find myself breaking out the torch
