I have a problem with excessive moisture on some of my windows and doors in my garage since I insulated it. Here are some stats..
poured foundation, sealed with perimeter drain
vapor barrier under concrete slab
22' x 40' x 8 1/2'
2" x 6" walls
Sill Seal
Vinyl siding over house wrap over 7/16" OSB
R19 Owens Corning pink with vapor barrier in the walls
R29 blown cellulous insulation (9 1/2") in the attic, no vapor barrier (per mfg recommendation)
Well ventilated attic
7/16 OSB interior sheeting, all seams and corners caluked, painted with latex paint
Prior to insulating and finishing the garage I had NO moisture problems at all for 2 years. The moisture seems to gather on the insulated overhead garage door and the stationary Pella windows. The crank out casement Pella windows do not have moisture. There is a huge temperature difference between the outside and inside even when the garage is not heated. The other day it was 4* outside and 48* inside without heating it and it rarely goes below 50*. This seams great, but the moisture is excessive. I am really worried that I am going to rot out the (expensive) aluminum clad Pella wood windows and the framing under them, because the windows and overhead door are literally dripping. I am hoping this is because of all the new wood, insulation, and paint I have put on. Maybe things need time to "dry out"???? If this problem persists next winter I am really gonna get worried. Any ideas would be appreciated. Thanks, Shawn
22' x 40' x 8 1/2'
2" x 6" walls
Sill Seal
