I am planning to install a 12" round duct 20' long with a Continental inline 840cfm centrifugal fan. This will be a straight duct run through the wall with a simple pressure activated backdraft damper and exterior hood. Shop size is 26'x30'x11'. Duct run will be at 10' high and 4' from the shops rear wall. Only wall openings are the doors on the shops front 26' wall, which is also the direction from the weather (pressurizing) often making fume evacuation slow.
Desiring the most even scavenging from the ducts length as possible, I am leaning toward 4 equidistant 3"x12" return grilles on the trunk. This is just based on equal sq/in numbers for the trunk and intake grilles. Would be very interested on any input before I made the purchases.
I have attached a couple images depicting my idea. Thanks for your time.
